SILENCE IS GOLDEN!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Click here for the full range
OcUK understand that our customers are looking to strive for that little extra over any other customers. We know that many of you strive for quiet computing, some of you spend literally hundreds of pounds on watercooling to reduce noise! Well we have listened (no pun intended, honest) and created a range of cases which are pre-installed with amazing high quality accoustic dampening pads, which are finished off with a leather style surface to provide that extra level of premium quality that should be given to you; our customers!
These Tech Labs case includes the standard case in its default format as produced by the manufacturer but our expert technicans have spent time dampening it with our Foam Dampening Kits!
- Default cases; but noise insulated
- Pre-installed for your convience
- All foam dampening pads have a leather style finish surface
- Reduced accoustics
You should add optional 'fan packs' to go with them, premium fans option and xilence red wing option. Probably sell like hot cakes!
