Ive got all the components that i need for my HTPC build, however im going to be changing the coolers on them to something less noisy, as the pc will be going in the living room, so silence is key, along with cooling.
I wont be overclocking, i just was a stable machine which is quiet. I have the following components which are going to need cooling and made quieter:
Powercolor X800XT 128MB PCI-E (New quieter GPU Cooler Needed)
ASUS A8N SLi Standard Edition (Replaced with Zalman NB Heatsink, but is hot, see below)
Athlon 64 3200+ Skt939 (On stock cooler at the moment, new quieter cooler needed)
Silverstone LC16M-B (Dual 80mm exhaust fans, need replacing with quieter ones)
The above are the core components which are going to be making noise through the coolers that are on them.
At the moment they have all got stock cooling, apart from my mobo (A8N) which has got a zalman NB heatsink on it, however this gets really hot, so i was thinking about changing the NB cooler to something more adequate, perhaps a larger heatsink.
What i was wanting was recommendations for relatively silent cooling for the above components, as this will be going underneath the telly.
The psu i have is an enermax noisetaker so thats good, and the hd is a samsung.
Ive seen the arctic cooling GPU coolers which look adequate, but im not sure what these are like?
Id like any recommendations from anyone on replacement cooling for these components.
Thanks
Thanks
). A decent 54mb wirless connection will be able to stream HD media.
