I found the scythe quiet drive box wasn't very good, even when suspended. However my other identical raptor is in a nexus drive-a-way and thats incredibly quiet, i highly recommend that you get one. It will need suspending aswell to get rid of some of the vibrations, but so will any harddisk box.
Cheekykid said:
Common sense dictates that fans make noise no matter how slowly they run
Fanless psus make noise. The question is is it audible?
A nexus/yate loon d12sl12 running at 5v cannot be heard with the human ear from 1 metre, maybe even 30cm. Compared to running the radiator passively you'll see far greater performance with even very low airflow fans such as a nexus running at 5v.
If you find the noise of the seasonic a problem either its running at near full load or you are sitting with your ear to it. At low speed the fan in that should not be audible from 1 metre.
I would say that for a setup thats drawing a lot of power and with a very hot cpu a watercooled psu is a bad idea, as it will only add a lot of extra heat to the water that you'll just have to remove. If you really can't find a non watercooled psu thats quiet enough then look at getting a watercooled one and perhaps getting some more radiators and silent fans to dissipate the extra heat.
Zefan said:
This is the problem with attempting to silence your PC. Much anger can result as you spend hundreds only to hear your hard disks clicking more clearly
Very true. Its a never ending loop i'm finding, and an expensive one too.
