- 18 May 2010
Hi,
I'm currently using a £10 logitech membrane keyboard, the membrane doesnt bother me I'm enjoying the silence but the backlit or lack of does bother me
I would appreciate recommendations for a backlit keyboard, silence is most important and gaming will be the primary use
I would prefer no software, not bothered about RGB but really want the keys to be backlit in white so might need RGB and software to achieve that? I cant find anything that comes with plain white backlit keys
Obvious choice would be Logitech Prodigy but you need software to change the colour and wondering if I've missed any keyboards that have white backlit keys as standard
Budget up to £100 but can spend more if it ticks all the boxes
Thanks
Thanks
