- 10 Apr 2019
- Grimsby UK
Hey all, hope you are doing well!
It's time for another build to wrap up 2022 and so I am putting together a build in one of my favorite cases, the be quiet! Silent Base 802.
A huge thank you to be quiet! for sending over this case and a few other bits to get this one going. To start I ahve the Silent Base and a Dark Power Pro 1200W to throw into this system.
For this build I want to incorporate a display, in the same way I did for be quiets! 20th Anniversary build recently while I was at KitGuru and keep the theme again black and orange throughout, but a little darker than the Pure Base 500FX looked.
Moving on, the motherboard I will be using is the MSI Z690 Carbon Wifi, crammed with a 12900K and full of Seagate FireCuda 510s and 530s, for a total of 8TB of fast NVME storage, and as you can see I will be going with Alphacool as usual for my cooling on this build.
Again a huge thank you to Alphacool for sending over everything I am going to need for this build including an Apex VPP pump, a ST30 and an XT45 radiator, both at 360mm, a 30 Series GPU block, and all-black Eiszapfen fittings. There will be a mixture of hard and soft tubing here as the pump will be located in the spacious PSU shroud and have bulkhead pass throughs to the GPU and radiators.
So il get some work done and be back with an update soon!
