Silent bathroom extractor fan with auto shutters and timer
5 Aug 2006
Kent, UK
Hi all,
I'm looking for a good quality 'silent' (20-25 dB) bathroom extractor fan that has auto shutters and timer. 100mm size.
I can't anything that's has all the requirements. Hoping someone here has a suggestion.
This doesn’t quite meet your requirements 100% but the CV2GIP that I have operates at 10dB constant (essentially circulating a small amount of air at 1W power) and then when it detects moisture, it’ll jump up to deal with it. You can adjust the low and high speed settings anywhere between 10-38dB. The vent is 100mm diameter.
Thanks for that. Looks good, I hadn't considered a continuous extractor fan before. Are they designed to work with heat recovery systems? Would it be a bad idea to install if not using heat recovery?
Also, how does it cope if being blasted by wind from the outside?
Ideally you would have a backdraught shutter on the external wall, whether this plays up with the constant running fan I'm not sure, but theory it shouldn't cause too much havoc.
This any good?
That looks ideal, thanks. I'd looked at several other vent axia fans on a different website but the model you found looks like it ticks all the boxes.
