Hi guys
Just after some help with deciding on some case fans.
I currently have a very quiet pc and I use the Asus fan Xpert to slow down the fans. I have a 200mm on the front and 120mm generic corsair on the back. I love this set up as it is so quiet. Both fans run silent at very low rpm.
I need to build a new system for my mate in a Corsair 750D. I was thinking of having 2 x 120/140mm fans on the front and a single 120/140 on the back. Im looking for three ultra quiet fans that can be controlled by the motherboard and dont have any bad sounds like ticking when they are ran at very low rpm.
I have been looking at these ones:
be quiet - Silent Wings 2 PWM, 140mm
Noctua NF-S12A PWM
The system will have a very quiet components in so the case fans really need to be silent. Anyone used these two fans or can give me some of their opinions please?
Thanks
Noctua NF-S12A PWM
Thanks
This is even sadder because Thermalright is about to release it in a square housing.
