Silent cooling for a 2ghz dual core cpu
23 May 2004
I have just bought two of these for office use:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-171-IN&groupid=701&catid=6&subcat=793&name=Intel%20Core%202%20Duo%20E2180%20%22LGA775%20Conroe%22%202.00GHz%20(800FSB)%20-%20Retail
My problem - thems stock hsf are incredibly loud! not good for getting the work done.
Basicly i'm looking to spend tops £15 each so £30 total for a cooling solution that is wisper silent! Fanless would be great but defo be good to be very very quiet.
Many thanks
M
Did you enable the fan options on the motherboard? Are there any fan options on your motherboard?
If there is then you can just enable it and the stocks fans should slow right down and becomes very quiet?
Check in the BIOS/Health Page?
