The corsair fans are nice but gonna have to try the apache black as its almost have the noise of the corsair I'm running and got the same max airflow?
Sweet find m8
just thinkng about it would it be the amount of air the fans pushing thats making the noise?
or changing it to a lower db fan make that amount of difference ?
The dB numbers written in the specs of fans mean nothing whatsoever. Literally nothing. You should be able to compare two fans by the same manufacturer, but even that's not certain. Reviews (sprc in particular) are more reliable.
Well they are, sort of. But one company might measure from 5 feet away in a closed case whereas another might measure from 12 inches away in open air. There's no standard measurement, unfortunately.
