- 12 Dec 2006
hi
my system currently has:
2x 120mm blue alaska fans
3x 60mm blue alaska fans
which sounds a bit like a jet engine starting up lol....
i need to replace them with some silent running fans which a quite when running a full speed as the system is located in quite a tight space where the fans need to be on full to get a good air flow going.
can anyone recommend some good fans which are quite on full speed settings, if they were to light up that would be good as well.
