Silent, low power to replace ageing C2D machine
18 Oct 2002
North Wales
Hi there,
I'm after something to upgrade and replace my ageing C2D E6300 @ 3.1GHz based machine.
I'm after something faster, so maybe an i5 based system? But main priority is that it runs quiet and uses low power.
I already have a passive Geforce 9400 which'll do me for graphics, unless I can get something better built in without spending extra.
What silent PSU would be sufficient to power it? The rest of the system will be 8gb RAM and 2 hard drives, so it shouldn't need to be that beefy...
Thoughts?
One of the new sandy bridge CPUs would be my recommendation, they are very fast - plus they are also cool running and have low power usage (considering their performance).
You could get a passive CPU cooler (thermalright HR-02) and a passive PSU (like the seasonic X-400), and this will keep yours system very quiet. That said, you would want a case with a few low-speed fans to ensure the heatsinks get sufficient airflow.
You could also investigate a pico PSU - as your power needs are going to be rather low.
As for which CPU to get - the i5 2300 would work fine. However, I would suggest the i5 2500K - it has a higher clockspeed of 3.3GHz and the Intel graphics processor onboard is actually pretty good. Hence you wouldn't need to run the Gefore 9400 - which should save power and aid case airflow.
Don't really want to fork out on a £120 PSU, so I could see how loud I found my current one with a passive CPU also.
Will look at some reviews for that thermalright, my last 2 CPU coolers have been thermalright and they've been pretty good.
What advantages are there with a P67 board, over a H67 one? I won't be gaming so I don't think I'll see any benefit?
The H67 allows you to use the graphics chip that is built on the CPU. It also allows you to use the new Intel Quick Sync Technology - which is very cool if you are transcoding h.264 video. However, H67 does not allow overclocking or multi-GPU arrangements.
The P67 does not allow you to use the in-built graphics or the Quick Sync. But it does allow overclocking and multi-GPU arrangements.
For your uses it sounds like H67 is the best option. Though, if you do want to overclock and use your 9400 card - then P67 would make sense.
Ah, yeah the i3 might be enough actually - plus lower TDP. I'm not planning on buying until next month anyway so I'll see what happens.
Nice link Marine :)
Looks like the Core i5 2500T is a chip to keep an eye on if you are doing multi-threaded work. SB quad core, stock 2.3GHZ, turbos up to 3.3GHz and a TDP of 45W :)
I've been looking around for an i5 2500t for a planned mini-itx/pico psu/1 fan system.
Can't find any info at all about them. Are they going to be hard to get hold of? So far even google is turning blank.
