- 6 Dec 2006
- Barnsley
I have a HTPC and the case is a TrendSonic with a accompanied PSU.
I want to take the PSU out as it is very noisy and will no doubt be cheap and tacky.
I want to get the most silent PSU I Can for no more then £50
It will be running the following kit
Q6600 (Stock)
4 gig Cheap Samsung Ram (to be replaced with dual channel soon)
4670 512mb Graphics card
1 x LightScibe DVD Rom
1 x 500gb sata 2 hard drive
1, cheap TV tuner card
Also some USB bits like web cam and wireless mouse & Keyboard
I will upgrade the ram at some point for some decent Dual channel stuff and also tweak the CPU as i know they clock well.
What would you guys recommend as I want it to be as silent as I can get it as in living room?
Q6600 (Stock)
