Silent running 4800 series?
12 Apr 2008
With all the reports of the high temperatures the new ATI 4800 series run at, does anyone reckon, or even better know, if it is likely or for that matter possible to run one of these cards silently?
On another thread on here it shows an aftermarket cooler running passively and been 30 degrees better than the stock cooler under load so yes.
They are only running hot cause the fan is running at 14%. People are reporting only 50 degrees with the fan at 40%.
Plus under water they don't go past high thirties which is much less than my 8800GTS G92 512Mb so I would say overall they are cool.
