Silent SFF PC for General usage and light gaming
16 Oct 2007
London
Hi All,
I have been brainstorming for a while now on my next Desktop/SFF PC and I believe I ve gone beyond the need for water Cooling, High end gaming phase, so I basically need a small PC for general usage and for some light gaming if required. I currently have the Phenom x II 550 unlocked. I have a sealed all in one Water cooling unit and an asus 550 Ti graphic, I have a 128GB SSD and 1TB drive which is all I want. My requirement for the new Build is:
Basically Silence is my main priority now and size.
I want something really small and silent, I was planning on going the factory build route but decided against it again. IF I can get the right small case that would be Silent then I am fine. IF using the Graphics card will generate more noise please advice a processor with suitable GPU inbuilt etc.
Looking to spend about £300 to £400 maximum considering I have drive and Graphics. Also would my Current 450W PSU be too noisy? if Yes I could do away with it and get another.
Also something smallish is fine does not have to be SFF forcefully.
Thanks in advance.
