22 Feb 2007 at 06:57 #1 FunkyT FunkyT Soldato Joined 27 Aug 2003 Posts 3,464 Recommendations please - thanks lads!
22 Feb 2007 at 09:31 #2 melbourne720 melbourne720 Associate Joined 26 Sep 2006 Posts 1,945 Location West Bridgford I silenced my dad's PC with this:- http://www.zalman.co.kr/eng/product/view.asp?idx=33&code=005 Very quiet, even with the fan at full wack.
22 Feb 2007 at 12:03 #3 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 32,865 Location Rutland http://www.overclockers.co.uk/showproduct.php?prodid=HS-004-TI&groupid=701&catid=57&subcat=
22 Feb 2007 at 12:54 #4 FunkyT FunkyT Soldato OP Joined 27 Aug 2003 Posts 3,464 Thanks lads. I was also looking at this one: http://www.thermaltake.com/product/cooler/retail/a1889-01/a1889-01.asp Any good?
22 Feb 2007 at 12:56 #5 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 32,865 Location Rutland FunkyT said: Thanks lads. I was also looking at this one: http://www.thermaltake.com/product/cooler/retail/a1889-01/a1889-01.asp Any good? Click to expand... They're ok, not as good as a heatpipe cooler. But if you're not wanting to clock the CPU to death then it'll be fine
22 Feb 2007 at 14:50 #6 Mr-White Mr-White Soldato Joined 12 Nov 2002 Posts 14,600 Location In my own little world you can only do one or the other..silence or performance, if you want both go water cooled. as for silence you cant really beat a zalman. MW
26 Feb 2007 at 13:48 #7 FunkyT FunkyT Soldato OP Joined 27 Aug 2003 Posts 3,464 Thanks ladies, I've just ordered: 1 x Zalman CNPS7000B-Cu Hopefully it should do the trick!
