- 11 Dec 2005
- Cheshire
Introducing our unique range of "SPEC OPS" gaming systems. Based around the truly epic Corsair Vengeance C70 case and the Asus Sabertooth range of motherboards. We have 3 systems to fit every need and budget. Fully watercooled courtesy of the Corsair Hydro 80 CPU cooler and our unique Nvidia GTX 680 2GB Hydro Cooled graphics card for the ultimate in stealth.
High airflow and silent operation allows us to deliver system performance and temperatures akin to that of a fully custom watercooled system, for considerably cheaper, with less maintenance and complication.
Available with a FREE copy of Ghost Recon: Future Soldier with the first 25 orders. A perfect match for such an awesome system.
SPEC OPS .50 CAL Intel Core i7 3770K 3.40GHz @ 4.30GHz DDR3 Quad Core System ** FREE GHOST RECON FUTURE SOLDIER GAME ** @ £1688.47 inc VAT
The "SPEC OPS .50 CAL" features an Intel Core i7 3770K overclocked and guaranteed to a stable 4.30GHz. With four processing cores and dual channel DDR3 memory the "SPEC OPS .50 CAL" powers through applications and games with equal ease. Designed for gaming on the edge, the "SPEC OPS .50 CAL" delivers blistering performance and amazing DX11 visuals courtesy of the Nvidia GeForce GTX 680 2GB watercooled graphics card, for ultimate power and silence.
Why Should You Buy This System?
- A guaranteed 4.30GHz performance for the price of 3.40GHz
- Quad Core processing and DX11 performance.
- USB 3.0 compatible system
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- Full system watercooling for the CPU and GFX card
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: Corsair C70 Vengeance - Military Green
- Power Supply: Corsair GS Series 800W PSU 80+ Bronze PSU with optional White, Red or Blue LED Lighting
- CPU: Intel Core i7 3770K 3.40GHz @ 4.30GHz CPU
- Motherboard: Asus Sabertooth Z77 DDR3 Motherboard
- Cooler: Corsair H80 All-In-One Hydro CPU Cooler
- RAM: Vengeance Low Profile 16GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 1TB HDD
- Graphics Card: OcUK Nvidia GeForce GTX 680 2GB GDDR5 Watercooled Card
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Ultimate stealth power! If you need maximum power all the time, the "SPEC OPS .50 CAL" provides performance by the bucket load.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
*Buy any system from Overclockers UK with Windows 7 between now and January 31st 2013 and once launched, you can upgrade to Windows 8 for just £14.99! See full details here:http://www.overclockers.co.uk/LP/windows8_upgrade.php
Only £1688.47 inc VAT.
ORDER NOW
SPEC OPS 12 GAUGE Intel Core i5 3570K 3.40GHz @ 4.30GHz DDR3 Quad Core System ** FREE GHOST RECON FUTURE SOLDIER GAME ** @ £1528.49 inc VAT
The "SPEC OPS 12 Gauge" features an Intel Core i5 3570K overclocked and guaranteed to a stable 4.30GHz. With four processing cores and dual channel DDR3 memory the "SPEC OPS 12 Gauge" powers through applications and games with equal ease. Designed for gaming on the edge, the "SPEC OPS 12 Gauge" delivers blistering performance and amazing DX11 visuals courtesy of the Nvidia GeForce GTX 680 2GB watercooled graphics card, for ultimate power and silence.
- Case: Corsair C70 Vengeance - Artic White
- Power Supply: Corsair GS Series 600W PSU 80+ Bronze PSU with optional White, Red or Blue LED Lighting
- CPU: Intel Core i5 3570K 3.40GHz @ 4.30GHz CPU
- RAM: Vengeance Low Profile 8GB DDR3 1600MHz Dual Channel Kit
Service Package
Ultimate stealth power! If you need maximum power all the time, the "SPEC OPS 12 GAUGE" provides performance by the bucket load.
Only £1528.49 inc VAT.
ORDER NOW
SPEC OPS MAGNUM AMD Bulldozer FX-4 4170 4.20GHz DDR3 Quad Core System ** FREE GHOST RECON FUTURE SOLDIER GAME ** @ £1337.48 inc VAT
The "SPEC OPS MAGNUM" features an AMD Bulldozer FX-4 4170 4.20GHz. With four processing cores and dual channel DDR3 memory the "SPEC OPS MAGNUM" powers through applications and games with equal ease. Designed for gaming on the edge, the "SPEC OPS MAGNUM" delivers blistering performance and amazing DX11 visuals courtesy of the Nvidia GeForce GTX 680 2GB watercooled graphics card, for ultimate power and silence.
- 4.20GHz quad core CPU
- Case: Corsair C70 Vengeance - Gun Metal Black
- CPU: AMD Bulldozer FX-4 4170 4.20GHz CPU
- Motherboard: Asus Sabertooth 990FX DDR3 Motherboard
Service Package
Ultimate stealth power! If you need maximum power all the time, the "SPEC OPS MAGNUM" provides performance by the bucket load.
Only £1337.48 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
