Hi,
Be Quiet have finally released the Silent wings 3 after announcing that they were looking at improving the Silent Wings 2 which was a very successful fan. The Silent Wings 3 has had a couple of design tweaks and comes in 4 different types including Non PWM, PWM and High Speed of both models. They are also available in the 120mm and 140mm.
The variety offers you different types of cooling with the non PWM and PWM for cases and CPU coolers and the High speed have the added option of adding them to your water cooling loop to improve those temps with some of the quietest fans on the market.
be quiet! Silent Wings 3 120mm PWM Fan @ £18.95 inc VAT https://www.overclockers.co.uk/be-quiet-silent-wings-3-120mm-pwm-fan-fg-036-bq.html
be quiet! SilentWings® 3 120mm PWM stands for state-of-the-art technology, virtually inaudible operation and superior cooling.
No Compromise Silence and Performance
be quiet! SilentWings® 3 120mm PWM stands for state-of-the-art technology, virtually inaudible operation and superior cooling. It meets all the requirements to be a perfect choice for heat sinks, PC cases and radiators.
Features:
- Virtually inaudible operation at max. 16.4dB(A)
- 6-pole fan motor with three phases giving very low power consumption and less vibration
- Advanced fluid-dynamic bearing enables super-long life span up to 300,000h
- Rubberized fan frame with funnel-shaped air inlets for extremely high air pressure
- Seven fan blades with optimized surface structures ensure excellent airflow
- Removable anti-vibration mountings reduce transmission of vibrations
- PWM controlled fan speed by the motherboard
- German product conception, design and quality control
- Three years manufacturer’s warranty
SilentWings® 3 PWM fans are your best choice for any application that requires the ultimate in quiet operation and uncompromised performance.
Specification:
- Dimensions (L x W x D), (mm): 120 x 120 x 25
- Fan speed @ 12V 100% (rpm): 1,450
- Airflow @ 12V (cfm, m3/h): 50.5 / 80.47
- Air pressure @ 12V (mm H2O): 1.79
- Noise level @ 12V 100% (dB(A)): 16.4
Only £18.95 inc VAT.
ORDER NOW
be quiet! Silent Wings 3 120mm PWM High Speed Fan @ £18.95 inc VAT https://www.overclockers.co.uk/be-quiet-silent-wings-3-120mm-pwm-high-speed-fan-fg-037-bq.html
be quiet! SilentWings® 3 120mm PWM high-speed stands for state-of-the-art technology, virtually inaudible operation and superior cooling.
be quiet! SilentWings® 3 120mm PWM high-speed stands for state of the art technology and virtually inaudible operation. The extremely high air pressure produced makes it a perfect choice for powerful water- and air-cooled systems.
Features:
- Great performance-to-noise ratio with 28.6dB(A) at 2,200rpm
SilentWings® 3 PWM high-speed fans are your best choice for any application that requires the ultimate in quiet operation and uncompromised performance.
Specification:
- Fan speed @ 12V 100% (rpm): 2,200
- Airflow @ 12V (cfm, m3/h): 73.33 / 124.58
- Air pressure @ 12V (mm H2O): 3.37
- Noise level @ 12V 100% (dB(A)): 28.6
ORDER NOW
be quiet! Silent Wings 3 140mm PWM Fan @ £19.99 inc VAT https://www.overclockers.co.uk/be-quiet-silent-wings-3-140mm-pwm-fan-fg-038-bq.html
be quiet! SilentWings® 3 140mm PWM stands for state-of-the-art technology, virtually inaudible operation and superior cooling.
be quiet! SilentWings® 3 140mm PWM stands for state-of-the-art technology, virtually inaudible operation and superior cooling. It meets all the requirements to be a perfect choice for heat sinks, PC cases and radiators.
Features:
- Virtually inaudible operation at max. 15.5dB(A)
Specification:
- Dimensions (L x W x D), (mm): 140 x 140 x 25
- Fan speed @ 12V 100% (rpm): 1,000
- Airflow @ 12V (cfm, m3/h): 59.5 / 101.09
- Air pressure @ 12V (mm H2O): 1.08
- Noise level @ 12V 100% (dB(A)): 15.5
Only £19.99 inc VAT.
ORDER NOW
be quiet! Silent Wings 3 140mm PWM High Speed Fan @ £19.99 inc VAT https://www.overclockers.co.uk/be-quiet-silent-wings-3-140mm-pwm-high-speed-fan-fg-039-bq.html
be quiet! SilentWings® 3 140mm PWM high-speed stands for state-of-the-art technology, virtually inaudible operation and superior cooling.
be quiet! SilentWings® 3 140mm PWM high-speed stands for state of the art technology and virtually inaudible operation. The extremely high air pressure produced makes it a perfect choice for powerful water- and air-cooled systems.
Features:
- Great performance-to-noise ratio with 28.1dB(A) at 1,600rpm
Specification:
- Fan speed @ 12V 100% (rpm): 1,600
- Airflow @ 12V (cfm, m3/h): 77.57 / 131.79
- Air pressure @ 12V (mm H2O): 2.16
- Noise level @ 12V 100% (dB(A)): 28.1
ORDER NOW
Reviews will be available with in the next couple of weeks.
All BeQuiet Fans Available Here
Other Fans Available Here
Features:
Specification:
ORDER NOW
Features:
Specification:
ORDER NOW
Features:
Specification:
ORDER NOW
Features:
Specification:
ORDER NOW
