Silentmax Hard drive silencer?
14 Jan 2005
Right jsut read a review on putting one of these on a hard drive, ill be using mine on 2 raptors and a maxtor 300gb, however one thing that looks aparent is it iwll block off the breathing hole? Is this right or will it be alright?
Thanks
NvidM
Yeah it will be fine. The silentmaxx is designed to house harddrives so there are no problems. The breating hole is only there to equalize pressure wit the outside of the disk, and as the silentmaxx isn't airtight it poses no problems. If you can afford it and want the ultimate harddrive silencer, then I would go with a Smartdrive 2002c. Ive got a couple and they're better than the silentmaxxs and do a much better job of keepeng the drive cool as well.
rar nigle said:
a nice big power surge :p
What was the point in that post seriosuly? If you have nothing helpful to add dont post it at all... thats not even funny its just some dumbwits attempt at humour or sarcasm.. hard to tell.
Some people on this forum are being total jacka**es recently. No doubt your the user that soon as he hits the post limit will go and start trying to flog gear in the members market. Do yourself a favour and leave now before u get banned and feel your 10 mins of worthless posts meant so much
/rantover
Back on topic, ive decided to go for the cooldrives, they look pretty good ;)
Cheers
Bon
Be nice. These are supposed to be friendly forums aren't they? (and yes, it was funny)
Very, very true
