SilenX SX12025?
17 Jun 2005
Cambridge, UK
Best fan for a Thermalright Ultra 120mm?
Does anyone know if overclockers stock SilenX IXTREMA 120mm for a Thermalright 120? They dont just checked!
So, what other fan do you guys recommend?
Nah, it doesn't
I am going nuts. Trying to find a suitable fan for a T-120 Ultra to cool a Q6600. I want to overclock (not massively just around 3ghz). What do you reckon?
Thanks Matt,
I've seen that you've recommended a 1200rpm Scythe. Any reasons why not to pick the Scythe 1600rpm instead?
Cheers,
Gabriel
mostly just noise.. they're both 3 pin fans anyway so you could whack them both into a fan controller and turn them down a bit. I just thought 1600rpm for a 120mm seems a bit ott and if you run it full whack then I expect you'd hear it.
Fair enough, got a Zalman Fan Mate 2 so that should do.
Any preference between the Noctua and the Scythe?
I am ordering now :)
