Silicon Bending Insert for 16mm acrylic
4 Dec 2012
Cant seem to find any at this size, basically looking for a Silicon Bending Insert for 12mm ID, 16mm OD bitspower acrylic tubing, does anyone have any ideas on where to find this size? Thanks
Doesnt seem to be any on the shop.
If you search that popular auction place for "metric nitrile cord" you should be good. Ive seen lots of people suggest that and its cheap :)
Thanks for the heads up pal :D .........UPDATE, ordered some 12mm metric nitrile cord on ebaY, Thanks pal.
