Silicon Insert, and general Q's
17 Sep 2013
Hello everybody I've done a good bit of watercooling now and moved onto Acrylic tubing and it's been a great experience so far but I need some help. I was slightly foolish in buying the Monsoon bending kit as I found most of it was complicating simple things for me amongst many things. I need a better silicon insert, the one that came with the kid was like a tiny tiny bit smaller than the inner diameter of the tubing and so when I bent the tubing on occasion the mouth would buckle in or the tube would be a little thinner where it's been bent. I'd like a few brands that you guys have used for inserts, I'm using 13mm tubing.
Another question whilst here is I have a liang ddc pump and replaced the top with an acrylic one, would it mess up anything if I mounted the pump on it's side? So when I'm looking into my obsidian 750d I can see the sexy acrylic top without the un-neat bottom portion?
