- 16 Apr 2015
Hi people.
Building a system with a high budget. My red line is £10,000. Target is £8000 roughly (anything under that while having a system that does what I need it to I will consider this a victory)
I need this system to do the following :
1) Smash games...utterly
2) Develop gaming assets using industry standard software (max/maya/blender/unreal engine 4 etc)
3) High profile model rendering/sculpting
4) Potentially dealing with number crunching while rendering out visualisations like they do in the oil and gas industries
5) Particle development
6) Video encoding
7) Video/photo editing (basically I have the full adobe CC suite and various plugins)
8) Be able to display 4k resolution with relative ease (scenario would be showcasing software/renders/ gaming environments etc on a large plasma screen)
I am planning to order in all the parts and build it myself. The slight snag is I havent built a water cooled system before....done my homework and researched the main principles and hardware like a boss but if you guys could focus on this area (particularly fittings/tubes combo) to give me guidance that would be awesome.
I have roughly an extra £1000 to play with inside my budget "green zone" so if there is any aspect of the system which is blatently stupid and you find yourself saying "why would you get/not get that?" then please shout out.
My proposed selection of goodies:
YOUR BASKET
3 x OcUK GeForce Titan X 12288MB GDDR5 PCI-Express Graphics Card £899.99 (£2,699.97)
1 x Intel 5960X Extreme 3.00GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail (BX80648I75960X) £869.99
1 x Corsair Vengeance 64GB (8x8GB) DDR4 PC4-19200C14 2400MHz Quad Channel Kit - Black (CMK64GX4M8A2400C14) £719.99
1 x Samsung 1TB SSD 850 PRO SATA 6Gbps 3D NAND Solid State Drive (MZ-7KE1T0BW) £469.99
1 x Asus Rampage V Extreme Intel X99 (Socket 2011) DDR4 EATX Motherboard £359.99
1 x SuperFlower Leadex Platinum '8Pack Edition' 2000W Fully Modular "80 Plus Platinum" Power Supply - Black £349.99
1 x Cooler Master Cosmos II Ultra Tower Case - Black £299.99
1 x Aqua Computer Cuplex Kryos XT .925 Silver Edition - Socket 2011 £249.95
1 x XSPC Twin D5 Dual Bay Reservoir/Pump Combo £199.99
2 x Watercool HTSF2 LT Radiator - 480mm - black/silver £117.98 (£235.96)
3 x EK Water Blocks EK-FC Titan X - Nickel £89.99 (£269.97)
1 x EK Water Blocks EK-FB KIT ASUS R5E - Nickel £74.99
1 x OcUK Value Blu-ray / DVDRW combi SATA - OEM £44.95
3 x EK Water Blocks EK-FC Titan X Backplate - Nickel £26.99 (£80.97)
3 x Three Fan Bundle - Overclockers UK & SilverStone - 120mm FQ121WC Watercooling Radiator Fan £20.99 (£62.97)
1 x Arctic Cooling MX-4 Thermal Compound (20g) £19.99
2 x Koolance LIQ-705 Liquid Coolant Bottle, Low-Conductivity, 700mL (Colorless) £14.99 (£29.98)
3 x EK Water Blocks EK-AF Angled 90 Degrees G1 / 4 inch - Black £9.95 (£29.85)
2 x Primochill Primoflex Advanced Tubing 19/13 - Clear £5.99 (£11.98)
1 x Mayhems Dye Ocean Blue 15ml £5.48
1 x XSPC LCD Temperature Sensor (Blue) V2 £4.99
17 x EK Water Blocks EK-ACF Fitting 13/19mm - Black £4.49 (£76.33)
Total : £7,188.42 (includes shipping : £16.85).
Minor points :
Sound levels from the fans are not that much of an issue.
Colour scheme is black/silver/blue
Hard disk drives are already sorted and so havent been included in this list.
Im guessing the total weight of this system might be high?
6) Video encoding
YOUR BASKET
Minor points :
