My system is as folllows:
Antec 900 case with stock fans
EVGA 780i motherboard
2 x 1GB GeIL Pc6400C4 (GX22GB6400UDC)
2 x BFG 8800GT OC2 (512MB) SLi (I play IL2 Forgotten Battles)
E8400 Fitted today (In the process of overclock testing) (Did have a E6600)
Arctic Freezer 7 Pro set in the BIOS to Run at 100%
Benq 24" monitor running at 1920 x 1200 (Hence the SLI for Forgotten Battles game).
I have a noctua NF-S12 Fan (120 x 120 x 25mm), and was going to fit it in the side panel that has space for it to blow air over the top of the RAM and the 2 video cards(using one of the motherboard 3 pin connectors), and then it was suggested by a friend that maybe it would be better to have it suck air out of the case and turn the up the settings on the 2 front fans that push air over the hard drives, and also increase the fan speed of the top 200 fan to extract even more air.
Has anyone any comments? There are many ways to cool the internals! Is there such a thing as the correct way? At present I am testing the CPU at 3.8ghz and the temperatures with prime running are 60 C on both cores using vcore auto settings that corresponds to 1.3 volts.
Note. When I am running the game (IL2 Forgotten Battles), the GPU's run at 81 and 84 degrees centrigrade, that was why I was thinking of pushing more air over the Graphics cards.
Any input appreciated.
Kind regards
Peter
Kind regards
Peter
(cpu/gpu/NB ram and drives too as these can warm up well lol
