Silly networking ideas
11 Jun 2003
Sheffield, UK
Has anyone run a few of the USB3 to ethernet ports through a hub back to a host machine and then hammered them a bit to check throughput?
I'm just spitballing here but the idea amused me:
8 x USB3 to ethernet adapters
2x 4 port powered USB3 hubs
8/9/10 port gigabit switch (if at least a 9 you could run the spare port to a router with DHCP to save having to set the 8 ports up each side).
Windows 10 each end.
Am I out of my tiny mind or do we think that might work? That's a 370MB/sec network between 2 computers if it works. Considering all that would cost about... £70 compared to pricing for 10Gbe/fiber. I wouldn't want to run anything even remotely important over it but for a bit of messing with homebrew NAS/etc... :D
If your concerned about throughout don't get USB3 adapters. They stuck. Most I've ever got out of one is 625mbps which is going to be about 70MB/s. Go for an Intel quad card. Also only one connection will be used anyway for each file transfer although you might have some success trying to force use of smb3.
Intel X520 10gb cards can be had for around £40, and a direct attach Cable for about £15.
So for not much more you could have a proper solution that will perform better.
