theres an adapter, Yellow looking thing with an hdmi slot on it.. but there was no cable ?.. i have an hdmi cable for the t.v but ofc with it being a mini slot on the back of the card it doesnt fit :/
ive confused myself twice now.. because the adapter the hdmi cable goes into.. which i used to see if it fitted on the gfx card (which it fitted)... but theres no hdmi slot on the monitor.. so i have to use the adapter to plug into the monitor... and still need a mini hdmi cable/connector thing to put in the back of the gfx card :S
i have the adapter for the hdmi to plug into the monitor, what i need is a hdmi to mini hdmi cable, as the mini hdmi bit is what i need to plug into the gfx card if im right, but i cant find it on the webby
thats the adapter, but as i said a standard cable is too big to fit in the gfx
lol theres no hdmi slot on the monitor, just a dvi (i think) which the yellow adapter plugs into.. i just need a mini hdmi cable to plug into the gfx card to connector to the adapter. if that makes sense lol
If it has no speakers built in, just use a DVI cable and forget about using any adaptors (chances are, if you use an adaptor on the monitor it won't pass audio anyway).
