yes plz mateTom|Nbk said:Yup it can tell you the gps speed limit, and the speed your going, as for speed cameras i can send you the database to upload![]()
gazzaa said:how do u make it tell you your speed mine tells me hrs how do i change it plz
Tom|Nbk said:Change preferences ---> Status bar preferences ---> tick Speed
gazzaa said:yes plz mate
gazzaa said:mine don't have status bar prefs
yea mate cheersTom|Nbk said:sent to garyaudley[at]hotmail.com
Since when did Tomtom show you the prevailing speed limit? Is this new with V6?ZG002 said:Speed limit and gps speed yes.. and out of the box..
Vertigo1 said:Since when did Tomtom show you the prevailing speed limit? Is this new with V6?
ZG002 said:Does on the new tom tom one V2
but like said.. not on all roads. but its there
Tom|Nbk said:did you have to enable it or is it already automatically enabled?
toyotacelicagt4 said:Any chance you could send the link to chaznanuan[at]gmail.com???
I've got the same problem as I usually rely on the speedcamera warnings quite often
