My first problem is that the Silver arrow fan in the CPU fan header on my MSI GD53 motherboard is always at 100% despite trying to change it in the Bios and with SpeedFan.
My second problem is that SpeedFan is saying my PSU (XFX 650w XXX Edition) is only outputting 10.47/10.56v on the +12v rail even when running Prime95 and FurMark at the same time. I know that software isn't the best way to monitor the voltage etc that the PSU is giving out (I'm sure my dad has a voltage meter or whatever it's called lying about) but that sounds very low to me, shouldn't it be around +-5% of it's stated output?
Anyone know if these problems are connected and what I should do. Both have only been in my system for a couple of days.
Thanks.
Thanks.
Often seems to be the case that it's the loudest component (or high end gpus under load).
