My Silver Arrow is connected to the SYS fan and the CPU fan bits on the motherboard, P8P67.
The fan connected to SYS Fan is running at around 800RPM, but the one in the CPU Fan socket is only running at about 600.
Firstly, how can I change the CPU fan speed?
And secondly, what speed would you recommend me set both fans at if I don't care about the noise at all (I wear headphones so can't hear a thing) and just want good performance?
Thanks.
Thanks.
