Silver Arrow performance with 2500k
20 May 2011
Aberdeen, Scotland
Hey all, just got my Silver Arrow delivered from OCUK and set it up today, and was wanting to know how my temps compare with others.
CPU is at 4.5Ghz @ 1.304v
Idle temps are around 30c-33c
Load temps are between 50c-55c
Room temp is around 24c if not a bit higher.
How am I doing guys? :D
(Not too sure on how good I applied the TIM, hate doing that. If you think it's worth redoing, say so. I applied a small rice grain sized amount to both the heatsink and the cpu and then just squashed it down)
Edit: Actually, will probably re apply later tonight. Core 0 is on average 3-4c cooler than all the other cores which are consistent. Hmm
Those temps are fine/great @ 1.3V+.
If you're running small FFTs with Prime (even if it's blend) then those are solid load temps at 1.3V+ - as the continuous stress will be greater than any program/app is going to apply.
EDIT: Howevere, if the load temps are via apps/gaming then run either prime/IBT/ORTHOS etc to get an optimal load temp.
The IBT set to maximum put me at 55-64ish.
Still good? :confused:
And damn, Core 0 had about a 7c difference compared to 1 & 2. Will have to resit for sure I think. Dammit. :o
And I got my original load temps running blend mode in Prime, yeah.
Place silver arrow on a flat table and give a slight push sideways. Does it wobble?
I already checked that whole concave thing with a ruler before I set it up, it seemed flat enough. There was a tiny bit of concave showing but nothing major, very small.
very nice load temps,
dont worry too much about temp differences at load mine have difference of about 5-7C.
Would be very very very strange to see all 4 cores with exactly same temp under load.
Personally, IBT is brutal - it's great quick stress test but doesn't resemble everyday load temps.
Not a problem i've set up 4 SB rigs and two chips have had discrepencies of (+-) 9degrees (it's a sensor problem across the cores) with one or more cores. The first chip i had i reseated the HS 4 times to be sure - the other chip only twice. The load temps should level out the differences between the cores?
Those temps are fine - try small FFTs if you want to give the CPU greater stress but no app/game is going to test it greater than a blend test.
EDIT: How did you apply the TIM?
Load temps level out the difference between the cores?
Looking at idle, they're within 2-3c. At load the sensors/temps get to around 7c difference.
Edit: I applied the TIM by placing a small rice grain sized dot on the heatsink, and another on the cpu. Then I squished down and tightened the thing down (This was very, very hard in a FT02 with a 6950 card in the damn way, so I may have bumped it marginally a few times. Nothing to worry about right? Having to screwdriver those side screws down instead of using the tool supplied made it a pain.)
Edit: I applied the TIM by placing a small rice grain sized dot on the heatsink, and another on the cpu. Then I squished down and tightened the thing down (This was very, very hard in a FT02 with a 6950 card in the damn way, so I may have bumped it marginally a few times. Nothing to worry about right?)
You only need to apply the blob to the CPU and the place the HS on top - but, no, it shouldn't be a problem.
Were they defininetly rice size - as two pea size blobs would be to much.
I definitely think so, as I thought to myself that I was applying too little, not too much.
But I do have some spare iso alchol and the TIM that came with the SA, I could resit later if you think that's a good idea.
(Hopefully I don't slice my middle finger on the heatsink when doing it again - that was painful hahaha)
Core 0 and 3 are the lowest temperatures. 1 and 2 are the highest.
Same as my present chip.
My present temps running prime 95 small FFTs:
Core 0 - 50
Core 1 - 57
Core 2 - 59
Core 3 - 51
And my HS and CPU fans are only spinning at 50% - but my Vcore is lower than yours.
This is the CPU i reaseated 4 times with another cooler when i first got it - and i had the same anomolies.
Core 0 - 50
Core 1 - 57
Core 2 - 59
Core 3 - 51
Yeah that sounds like mine then.
I think both my HS and CPU fans are spinning at 100 since it doesn't make too much noise. Big 200 case fans at the bottom are at 50% though.
And damn, that's a nice vcore. I never really tried to bring mine down to see how stable it could be. :D
Sounds fine.
You've got quote a high vCore for 4.5GHz which is why your temps will be higher than mine.
How have you set your clock?
Sounds fine.
Well when I was trying to see how stable I could make it prime95 would keep failing after like 6 hours, I got frustrated, shooting it up to 1.3 and called it a day. Will need to try lowering it sometime, or maybe try for a 4.8 :D
Experiment - perhaps even drop 100MHz - my vCore goes up dramatically (relatively) when i push past 4.5Ghz.
I wanted a compromise between a moderate clock and quiet/cool running.
Dropping vcore to see what I can boot in at 4.5 so far set a 1.280 with CPU-Z reporting that it's drawing 1.264 whilst idle. Seems okay so far although temps didn't change much.
