Silver kill coil
8 Jan 2011
Where to get?
Any places that'll get it too me by Saturday? I have heard about jewelers having it but most references to that are in USA forums. Just wondered if anyones got it from a UK jewelers
I flush mine with the shower on hot first then run some distilled water to make sure its nice and clean.
Would I be fine by using distilled until it arrives?
this is my first WC loop so I just also wondered how i'd get it in when the loops been created and is already pumping
I see, well i'm all out of luck today. My mum said she had destilled water but she has de-ionised water :(
Also this kill coil is curled so that it can be put in a tube.
I have a cylinder reservoir, won't it get stuck at the over one of the holes?
the coil will easily fit in a piece of tubing it's really quite small, it shouldn't get stuck, dont really think it matters either way tbh :)
I meant it may get stuck in the reservoir at the bottom as the in/out holes are at the bottom so it might end up wedged in there :(
Destilled water is the way to go isn't it? Quite a lot of the internetz says de-ionised is basically destilled. I'll just get me some distilled tomorrow :)
Google shows 5 locations with stock and one has multi colored letters in it's name and should have made you think of it, has 99% of everything you want and don't want
Had to order 45 degree compression fittings for my apogee xt because my normal fittings don't fit! Though you can flip the inside inlet 180degrees but I wouldn't want to upset the natural flow :)
I have a 3 pin I think CCFL connector on my frozenq reservoir but I don't know how the hell to connect it AHAHA. Never put cold cathodes in a pc before...
