** SILVERSTONE ARGON COOLERS **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Due any day now we have the fantastic new range of cooling solutions from Silverstone.
I saw these previewed at CeBit this year and they look incredible, what shocked me the most is the prices when I came to buy as they look far more expensive than they actually are.
Silverstone Argon SST-AR01 CPU Cooler - 120mm (Socket 775 / 1155 / 1156 / 1150 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £25.99 inc VAT
The Argon series coolers are designed to provide the best cooling solution for your CPU. The Argon AR01 features three 8mm thick copper heat pipes connect to the base using heat-pipe direct contact (HDC) technology.
Socket 775/1155/1156/1150/1366/2011/AM2/AM3/FM1/FM2 Compatible
A new, compact 120mm PWM fan with excellent balance of airflow and noise is included to provide forced-air heat dissipation with the ability to cool components around the CPU area. For users requiring higher performance cooling at reasonable price, AR01 is a great choice.
• Great balance of silence and performance
• Three Ø8mm heat-pipes and aluminum fins for excellent heat conducting efficiency
• Heat-pipe direct contact (HDC) technology
• Patented anti-vibration fan mountings for easy installation and silent operation
• Includes compact 120mm PWM fan for excellent cooling and low noise
• Intel Socket LGA775/115X/1366/2011 and AMD Socket AM2/AM3/FM1/FM2 compatible
Only £25.99 inc VAT.
ORDER NOW
Silverstone Argon SST-AR02 CPU Cooler - 92mm (Socket 775 / 1155 / 1156 / 1150 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £27.95 inc VAT
The Argon series coolers are designed to provide the best cooling solution for your CPU. The Argon AR02 features three 6mm thick copper heat pipes connect to the base using heat-pipe direct export technology(HDC). A new, compact 92mm PWM fan with excellent balance of airflow and noise is included to provide forced-air heat dissipation with the ability to cool components around the CPU area. For users requiring higher performance cooling, AR02 is the best choice.
• Advanced silence and performance
• Three Ø6mm heat-pipes and aluminum fins ensuring the best thermal conducting efficiency
• Heat-pipe Direct Contact (HDC) technology
• Patented anti-vibration fan mountings for easy installation and silence operation
• Includes compact 92mm PWM fan for excellent cooling and low noise
Only £27.95 inc VAT.
ORDER NOW
Silverstone Argon SST-AR03 CPU Cooler - 120mm (Socket 775 / 1155 / 1156 / 1150 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £55.99 inc VAT
The Argon series coolers are designed to provide the best cooling solution for your CPU. The Argon AR03 features six 6mm thick copper heat pipes connect to the base using Heat-pipe Direct Contact technology(HDC). A new, compact 120mm PWM fan with excellent balance of airflow and noise is included to provide forced-air heat dissipation with the ability to cool components around the CPU area. For users requiring higher performance cooling, AR03 is the best choice.
• Six Ø6mm heat-pipes and aluminum fins ensuring the best thermal conducting efficiency
• Innovative anti-vibration fan mountings for easy installation and silence operation
Only £55.99 inc VAT.
ORDER NOW
