Hi Guys
I have put together our Silverstone Braided cables into configurable bundles to make it easier to choose the cables to suit your build.
The way that our website presents them isnt the best and there is no way of really sorting by colour. Now these bundles should highlight the cables you need giving you the base cable set and a choice of PCIe options as well as the molex to 4x SATA adapter.
The cables themselves are amongst the best quality extensions that I have seen in our range and best of all, they are amongst the cheapest options for anyone looking to add a touch of flair to their build.
Each colour option has a range of choices so the prices do differ, but check them out have a play with the drop down menus to get the bundle to suit your needs.
Silverstone Cable Extension Value Bundle - Black
Silverstone Cable Bundles are designed to assist you in kitting out a full system with stylish and attractive cable extensions. Compatible with all power supplies on the market, this bundle takes the hassle out of choosing your cables with easy to use dropdown menus allowing you to pick a bundle that suits your needs.
Each bundle includes:
- Silverstone 24-pin ATX 30cm Extension.
- Silverstone 8-Pin EPS to 4+4-Pin 30cm ATX/EPS Extension
You are then given the option to choose a 6-Pin or 8-Pin PCIe extension for your Graphics Card.
An additional PCIe extension is also available in a 6-Pin or 8-Pin PCIe extension option.
In addition to these choices, we also offer colour matched Molex to 4x SATA connector that you can use to power 4 SATA devices from a single MOLEX connector. Perfect for HDD cable management.
ORDER NOW
Silverstone Cable Extension Value Bundle - Red
ORDER NOW
Silverstone Cable Extension Value Bundle - White
ORDER NOW
Silverstone Cable Extension Value Bundle - Black & Red
ORDER NOW
Silverstone Cable Extension Value Bundle - Black & Gold
ORDER NOW
Silverstone Cable Extension Value Bundle - Black & Blue
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
