Silverstone CP06 compatability
17 May 2012
Firstly i have the antec p182 case and want to ensure this is long enough for four drives in the bottom cage; it says there is 4.3CM between each power port?
Also what is the SATA 15pin Power adapter connector is that just a normal sata power cable; or would i need to buy an adapter? I have the Antec Quattro 850W PSU. Thanks
