Hi all,
I've recently started a build with a Silverstone Fortress and the psu im putting in - Enermax Modu82+ seems to be having some clearence issues,
Its a real tight fit getting the mount holes to line up, and then the fan is only really half on the mesh grill at the bottom.
Can anyone else with a small size psu check this out and see if you have the same issues or offer any help?
thanks
thanks
