Permabanned
- 15 Nov 2008
only after ppl had started recomending it
No doubt it has great CPU cooling because of fan blowing directly into it but rest is more problematic:The fortress would be better for cooling, just because of those mahoosive fans.
From those my choise would be ATCS:CoolerMaster ATCS 840
Lian Li Armorsuit PC-P80
Any opinions on these? Leaning towards the 840, as I'd imagine it will be a fair bit quieter than the P80 and will possibly be easier for cable management too.
B70 is basically blinged version of A70/7010 and lacks its mid case fans which keep airflow pointed towards hot components while HDD tray increases size of airflow obstacle inside HDD cage so despite of slightly bigger (and lower pressure) 140mm intake fans I doubt there's any difference in cooling performance. (at least to better direction)Also just spotted the Lian Li PC-B70, which seems pretty good value compared to the above two. Anyone have experience of this, or the B71?
Also another negative on the Lian Li is the poor cable management as standard, easily fixed by cutting a few holes I guess but already done for you in the Fortress.
Only problem with the fortress is the silly design on the top fan filter.
