- 22 Sep 2010
- Torbay
Hi guys,
I'm getting an FT-02 and the Corsair AX850 power supply.
I was just wondering if the supplied cables will be long enough to run behind the motherboard? Mainly I was concerned about the SATA power cables reaching the HDDs and optical drives as it is a relatively long case.
I will be running 2 HDDs and an SSD which will be mounted on the bracket along with 2 optical drives. I will also be running 2 6950s in xfire and would like the PCI-E and motherboard connectors to run behind the motherboard panel too.
I dont want everything to turn up and then realise I need more cables but equally I don't want to buy anything I don't need as will be spending enough already!
Any feedback, as always, will be greatly appreciated.
