- 11 Jan 2011
Hi, i have a silverstone FT02 case and the front audio panel connector has stopped working.
when putting a headphone jack in it doesnt work but if i apply pressure and push the audio jack down it works but then when leaving it go it pops up slightly and stops again.
i thought at first i might have damaged it by using to much force to pull it out but i tried the second audio connection which has never been used and its exactley the same.
not sure what the problem is as i have only had the case for 2 months.
can it be fixed or replaced?
