Silverstone FT03 Coolers....
30 Oct 2008
Evening all,
I've a real thing for the FT03 (currently have an FT02, but would like to downsize....). Haven't much I'd need to fit and am going mATX or mini ITX. I do have a Thermalright Silver Arrow, and would ideally still use that if it fits and still will keep all cool
Anyone with experience of this combo, or has suggestions of an alternative?
I'm all ears...
Cheers and all the best,
Rich
I had a corsair h60 and also a arctic freezer i30 in my ft03 at some stage, i found the i30 the much better cooler...
Not sure of the max cpu height on the ft03 though
Cheers - thanks for the heads up about that. Never really been convinced by the H60/80s etc - too many mixed reviews.
How are you finding the case? Again, it seems to have mixed reviews?
Cheers,
Rich
Cheers,
Rich
I havent got it no more... Absolutely nothing to do with the case but i had no room for it in my bedroom, i needed a shorter/height wise case
One of the best if not the best case i have ever owned..
Enough room in the back for an ssd and couple of 3.5" hdds
I would defo get a modular power supply though, because i tried using the superflower golden green power supply, but the cables were far too long and i wasnt using half of them..
So got the corsair RM750, which was ideal
Build quality, it is amazing, the panels are very thick metal and enough vents for cooling
I cannot find one fault with the ft03, apart from you need to use a modular power supply
If you haven't already grabbed the FTO3 you might want to check out the FTO5, moved from a FTO2 to a 350d for mATX, but i will grab a FTO5 when its available.
