Hi there, i recently bought a silverstone FT03 and loving it...but there is a tonne of vibration going through the case! its not the hard drives...and i only have the bottom intake fan and exhaust fan on the case, the 3rd fan doesn't fit due to my cooler and graphics card.
Both fans are connected to my motherboard and running at 500RPM according to my bios, at lowest speed possible any less they just stall on startup.
I thought it was the cpu fan at first, then i connected it to a fanmate controller and its only stopped the fan noise not the vibration. The vibration seems to stay even when all fans are turned on full.
Its getting so bad i have 4 cup mats under each rubber foot to stop the vibration from going through the floor...you can even hear it in the living room and my bedroom floor is insulated to keep the living room warm....
One thing that helped is taking all the side panels off...i cant help to notice but what case has steel/aluminium panels and NOT have rubbers where the slide on to? its just metal to metal!! it only helps but you can still hear my case vibrating the floor in the living room.
would my CPU cooler be causing this? there is no backplate, just 4 plastic thumbscrews which are quite tall. would they be vibrating against the motherboard tray ?
I can stop the vibration from going into the living room if i put the case on the table but i wish to avoid that for 2 reasons, the vibration is that loud even with headphones on and music, i still hear the vibrations! another reason is with my g27, my table shake a lot and the case sometimes wobbles around.
im not entirely convinced on the hdd mounting either
