Hi,
I have a HTPC built in a Silverstone GD05 case and wondering if I could improve the cooling?
CPU is a 2700x with stock wraith cooler so gets hot quite fast not to mention the noise. (I have a fan curve setup)
There is 2x 120mm Akasa Viper fans as intake & 1x 120mm Akasa Viper extracting heat.
CPU cooler will be getting replaced but limited to 12cm height I think it was.
Do you think drilling a few holes in the top panel above where the CPU fan is will help?
cheers
cheers
