Silverstone Grandia GD01 LCD Issues
23 Jan 2004
On my Boat, Drinking
Hello chaps
I recently built a PC around the Silverstone GD01 case which has an LCD and a remote.
I installed all the software and for a while the LCD/ Dot Matrix/ Whatever worked using the software supplied with the case (I'm using Vista).
After I left the case for a while and came back the PC had gone into hibination, I work it up and it hasn't worked since despite the back light working. It annoyed me so much I reinstalled Vista and it still didn't work.
The software seems to be a case specific version of iMON, it doesn't report any issues but just doesn't work. If you unload the software the backlight goes off which leads me to believe the thing is connected but I'm not sure what more I can do :(
MB
You can still use the normal Imon software on it, it doesnt have to be the one that came with the case. I've got the same one and I just downloaded the latest version, didn't even use the bundled CD.
I haven't even bothered with it at the moment. I think it's a bit naff, I don't want news headlines and loads of facts about my memory status scrolling across the front. Well annoying! The only good bit I can find is the EQ but it's really glitchy.
Do you know if I can use other software with it? I don't really like the imon software at all.
