- 28 Dec 2003
Hi,
Just a quick question about the LC18's touch screen, from the web site it looks like you plug the touch screen into the vga Dshell cable, but then if like me your plasma has only vga connection what do i plug into the plasma if the cables already used on the touch screen ? Or has it got somesort of loop through and if so, is it a powered loop through, because you need a powerd loop to keep and signal clean, at the moment I'm using a powerd vga splitter (17" TFT to 42" plasma). And finally can you turn off the touch screen when watching movies or has it got a standby mode.
Thanks.
Thanks.
