Hi all I'm going to be getting the Silverstone ML02 MoDT, i'll be putting a Abit AN-M2HD (the one with hdmi out), am2 dual core cpu, 2gb ddr2, dual PCI tuner tv ard and the Hiper HFA-20820-C1 Low Profile AM2 Cpu Cooler which is bang on 35mm tall.
The only thing is the power supply that comes with the ML02 is 120w, is that enough power to run all of this or is it just wishful thinking?
I'll be using the HTPC for HD media and recording and watching TV.
I'm basically down sizeing my current HTPC case which takes full ATX boards and mATX boards. So i'm using all the inards, I'm looking for a good looking mAtx case that small.
Thanks
Stephen
Thanks
Stephen
