Silverstone ML02
28 Aug 2005
I'm interested in putting together an HTPC with this case. However, there doesn't seem to be much information out there about it e.g. reviews, others who have built using it.
So I wondered if anyone here has any experience with it, and if so, how they found it. I'm hoping to put in a S939 MSI board with DVI out in but am a bit concerned that the 120w PSU just isn't going to cut it. Also, it's quite a shallow case so heatsink might be an issue. I'm thinking one of the Zalman low profile types might be a good choice. Any other ideas?
you two are aware that the case is designed for systems based around mobile processors, ie merom/yonah, turion etc so 120w would be fine. Its not really designed for use with s939 etc, although you may get away with the ee range of am2
Ok, cheers.
Would you say I could build a decent enough HTPC using this case - capable of playing all media content including HD material ?
I won't be using it for gaming or anything else.
