Silverstone ML03B ordered, what else do I need?
5 Oct 2009
Spalding, Lincs
I've had my HTPC for about a year now, built in and around a HP dx2250. Now's time to put it in a proper case.
Current specs:
Standard HP mATX motherboard
AMD Athlon 64 x2 6000+ (3.00GHz)
2x 2GB Kingston HyperX DDR2
2TB Samsung F4
ATI HD6450 1GB Passive
BlackGold BGT3620 TV Tuner
So to re-locate the above into the Silverstone case. So far this is what I've got:
YOUR BASKET
1 x Alpenföhn Panorama CPU Cooler (Socket LGA775/1156/1155/AMD AM2/AM2+/AM3) £19.99
2 x Fractal Design 80mm Silent Cooling Fan £6.98 (£13.96)
1 x Akasa AK-FY320 3 Pin Fan cable splitter (AK-FY320) £1.99
Total : £35.95 (includes shipping : FREE).
Anything else I might need, will the cooler fit also?
Since ML03 takes only low-profile cards, you need to make sure your graphics card and TV tuner card has low-profile brackets to use as well (if they are low-profile compatible in the first place). If not, you may have to consider getting new cards or looking for a different case.
