Silverstone ML09b
It won't fit.
The two PCI slots to the side are low profile. So you'd need a low profile card like this:
https://www.zotac.com/gb/product/graphics_card/zotac-gaming-geforce-gtx-1650-low-profile
And the one up top isn't suitable for a GPU.
Edit:
https://www.overclockers.co.uk/fractal-design-node-202-mini-itx-htpc-case-black-ca-061-fd.html
https://www.overclockers.co.uk/silverstone-sst-rvz01-raven-mini-itx-black-ca-364-sv.html
https://www.overclockers.co.uk/silverstone-sst-ml07b-milo-mini-itx-case-black-ca-375-sv.html
https://www.overclockers.co.uk/silverstone-milo-ml08-mini-itx-case-black-sst-ml08b-ca-419-sv.html
https://www.overclockers.co.uk/silv...case-black-window-sst-rvz02b-w-ca-422-sv.html
Any of those will take a full height, dual slot GPU. Some probably take a longer card too (I haven't checked).
Or, stick with the other case and buy a low profile GPU. Zotac make a LP GTX1650, which is as good as it gets AFAIK.
Thanks for the assist first time aiming small form factor so not used to having to be so precise.
Oh it takes a lot of checking. I've had times where I've been sure everything would fit, only to find that it doesn't and I've got to order replacement parts.
Did you catch the SFX PSU requirement on the ML09?
