Silverstone Raven 02
30 Jan 2011
Hey guys, with me getting a AMD ASUS 6950, I do have slight concerns over my current case, I'm sure it has ample space for it, but I've had my current case since I was 18, I'm now 23!
I was looking at the Silverstone Raven 02 case, I'll also be picking up a Coolermaster Silent Pro 850W Modular PSU, if it reaches over to the HD rack.
The only concern is the distance between the PSU and the harddrives & other drives, has anyone else used this case with a similar or the same PSU and is having no problems with cable length?
Thanks :cool:
edit* after watching a review, I have another question, I'm not sure what the length is on the AMD ASUS 6950, does it not sit at around 10 to 11 inches?
Looking at the case more, it does look like it maybe a tight fit, which is a shame, if it does fit then thats fine for me as I like the look of this case :)
Again, can anyone confirm this?
I'm hoping all is well, I tried finding this but most of the websites just talk about drive bay sizes...
My 6950 is slightly longer than my 4870x2 so I would say it is about 10.6".
It will fit in the RV 02, it can take cards up to 12" so you will have plenty of room.
*edit* just read your post again lol,
if the Sata leads dont reach you can always buy extenders, or have the sata cables routed along the top of the case?
6950 will easily fit in the case as said above,
Yeah, I was going to buy some anyway, but I got a reply off of a YT video of someone doing an unboxing, they said they would reach no problem.
I hope they're right, I really don't want to sit here an consider throwing my new parts in my old case! lol.
You should be fine with that PSU :)
I ahve an older CM 620 which is not sold anymore (early modular ones) but it fits a treat with a good amount of slack too.
