- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
The first shot shows the case next to a bottle of lemonade.
You may also note the bottom mounted 3 fans, they really are big fans. Great as it keeps the noise down, whilst giving good air-flow.
Next is the top down view of the top of the case, where the cables plug into the VGA, USB, sockets on the motherboard, and the power cord plugs in via the top also. This is the shot without the cover.
And with the cover attached.
Rear view of the vent for a 180mm fan and dust cover.
and
Few snaps of the front view.
Side of case with Windowed panel on.
Other side.
Another top-shot from the rear.
View from underneath with the fan vents, which all have removable dust filters. Note the tubing rubberised hole for your watercooling rigs.
and
Other side.
