Silverstone Redline RL06 mod
20 Apr 2015
Would it be possible to mod the Silverstone Redline RL06 front bracket for the 3x 120mm fans and squeeze 3x 140mm fans in, given that the case height is taller than 320mm.
Thanks
d
I doubt it.
A 140mm fan is not just 20mm taller than a 120mm, it's 20mm more diagonal so you would need width as well as height.
Well as the specs say it will accommodate two 140mm fans in the front, does anyone else know if it's possible to squeeze three fans in the front given the height of the case?
