- 6 Dec 2006
- Barnsley
Hi all,
So having a bit of a challenge keeping 2700x cool at stock speeds in a Silverstone rv03.
The stock cooler is too tall and I have clearance for a cooler max of 820mm. I have been reading a fair bit about low profile coolers and although is seems they would do the job in a normal case they wont in mine due to very limited air flow.
I have been looking at an a Corsair Hydro Series H60 but I am limited to room and wanted to make sure it will cool the above CPU well.
I do not intent to clock (be nice If I could) and noise is the main benefit as the rig is a gaming/HTPC in my living room.
Would the above AIO be suitable or could you recommend alternative options?
Thanks
Thanks
